Colors in the Detailed-File-View
taekwondo
Post by taekwondo »
How can I use the function "Use color based on file format" in the "Detailed"-file-view? The colors only occure on the "List"-file-view.
Thank you for your help. Regards TKD
Re: Colors in the Detailed-File-View
could you post a screenshot? Catalog is enabled?
taekwondo
Post by taekwondo »
yes, catalog is enabled.
Regards
you are not in details view??
