0.88: Some item in file list won't be deselected with Shift+Arrow
shokuzai
Post by shokuzai »
XnView: MP 0.88 - 64-bit
OS: Windows 10 - 64-bit
Effect: Inconsistent behavior in file selection
1.Open Browser and switch to thumbnail view.
2.Select an item in the rightmost column in the file list.
3.Select the next item in addition using the Shift key.
4.Press Shift+Left Arrow.
Actual behaviour: The latter item won't be deselected.
5.Select an item in the file list.
6.Select some preceding items ranging over multiple rows in addition using the Shift key.
7.Repeatedly press Shift+Right Arrow.
Actual behaviour: Each item in the rightmost column won't be deselected immediately when you come from one row to another, but the previous two items will be deselected when you reach the next.
Re: 0.88: Some item in file list won't be deselected with Shift+Arrow
shokuzai wrote: To reproduce:
Currently the item on next row is always selected, right?
shokuzai
Post by shokuzai »
The first item in the next row remains selected after these steps.
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
