Folder moving
obelisk
Folder moving
Post by obelisk »
I have 20-30k folders under a dir.
I want to move some of those dirs to a different subdir.
Can you add a method that moves all the thumbnails so it doesn't have to build again?
it's overa network, so it's very slow to rebuild.
jadO
Re: Folder moving
Post by jadO »
If you move them within XnvieMP I believe the thumbnail paths get updated accordingly. Did you check?
