i have a simple question. I can scan from a twain source and get a PDF file for each scaned page. Is it possible to scan pages and group them with a preset?
For example: I scan 10 pages and I want to create a PDF file after every two pages. So I get five PDFs each with 2 pages.
I need a few presets like, make a PDF File after one page, after two pages, after four pages, ....
Is that possible in XnView (with addons) or do I need another program?
Greetings
Sebastian
Batch conversion with twain source
Re: Batch conversion with twain source
That seems a rather specialised need: I doubt if it would be a priority for Pierre to add it given his current high workload, and I don't know of any scanning or post-processing utility that provides the function. Possibly XnTriq can suggest something...
But I think that it wouldn't be too difficult to create a batch file that could post-process a folder of scans the way you suggest, using the command line utility NConvert and some Windows command line code [cmd.exe or 'DOS'].
Alternatively, someone familiar with modern programming tools might be able to produce a simple Windows utility.
- Forum Librarian
- Image Access
- Batch Scan Wizard
Download the demo and extract BatchScanWizardManual.pdf from the MSI installer package contained in the ZIP archive (e.g. with 7-Zip).
- Batch Scan Wizard
- SolarSys
- DocScan Pro OCR User Manual: Document Template → Front page X mark
- O Imaging Corporation
- Fujitsu
- ScanSnap Advanced Operation Guide: Saving Scanned Images in Multiple PDF Files
Generate one PDF file per [ _ ] page(s)
CreativeWorld
Thank you ver much for that information and the alternativs.
