Show "Bits Per Channel" in the Status Bar instead of Total Bits
Luminous
Post by Luminous »
Hi, I noticed that XNview MP Shows the total bits of all the channels. So, an 8 bit RGB image is 24 bits, and an 8 bit RGBA image is 32 bits. I find this to be rather unintuitive because at a glance, looking at the total bits per image requires doing a bit of breakdown to determine the bits per channel. I have to check to see if the image has an alpha channel, and if it does, divide the total bits by 4 to determine the bits per channel.
Why not just simply display it like this? "4096x4096x24 (3 channels) (8 bits/channel)" or "4096x4096x64 (4 channels) (16 bits/channel)".
To me, this is way easier to understand and follows the Adobe Photoshop methodology of configuring your image to be displayed in "X Bits per channel".
Hope you consider!
Thanks!
