How to write text on picture XnviewMP?
I write, click OK but Text is not displayed.
Can't write text on picture XnviewMP
Re: Can't write text on picture XnviewMP
Using XnView MP 0.88 Image > Draw... ?Ekaterina wrote:How to write text on picture XnviewMP?
I write, click OK, but Text is not displayed.
The following points might help:
o Text size set is in pixels, I presume, so unless a large value is used text will appear small when image dimensions are large.
o After setting the text parameters, when the mouse cursor is moved over the image it should change into a small cross, which is the text insertion point when the left mouse button is clicked.
o After text insertion as above, the mouse cursor changes into a four-headed arrow which enables the entered text to be moved, until 'OK' is clicked.
Ekaterina
I did, but after OK the text is not displayed.
There was an issue in earlier versions when the screen resolution was scaled:cday wrote:Using XnView MP 0.88 Image > Draw... ?
Texts, rectangle and ellipse are placed in wrong location and size when font size diff 100%
Otherwise, could you please provide more details of the issue you are having.
