Xn-View MP 0.88 - does not open the last used directory at startup [solved]
masterjp
Post by masterjp »
Since version 0.88 I am not able to see the last used directory at startup. The required settings are correct. I tested the other setting for startup directory "specified" and it works correct. Please check it.
Jochen S.
Re: Xn-View MP 0.88 - does not open the last used directory at startup
Post by Jochen S. »
I can't reproduce, for me it seems to work. Are you sure the "last directory" is mounted/ available during next start of the application?
jadO
Post by jadO »
masterjp wrote:Since version 0.88 I am not able to see the last used directory at startup. The required settings are correct. I tested the other setting for startup directory "specified" and it works correct. Please check it.
Please check similar issue here: viewtopic.php?f=62&t=36246&p=145053#p145053
masterjp
Post by masterjp »
Thank you for your help!
The purge filelist on exit setting was the problem! Maybe another decription would be better.
E.g. purge directories/files list on exit.
