Problem with Fedora 27
junker
Post by junker »
Good morning,
it seems that the rpm packages don't work at all with Fedora 27:
- the 32 bit package has a problem of conflict with another package filesystem;
- the 64 bit package has a problem in finding a strange libqt5 file that I couldn't even find on the internete;
- the tgz packages don't work at all: I try them from the command line but nothing happens.
Is there any solution?
Re: Problem with Fedora 27
junker wrote: - the tgz packages don't work at all: I try them from the command line but nothing happens.
what's happened if you try 'xnconvert.sh'?
junker
Post by junker »
Nothing happens.
in a console?
junker
Post by junker »
xnview wrote:in a console?
I tried through terminal/command line... but nothing happens.
what do you have if you type ./xnview.sh?
junker
Post by junker »
xnview wrote:what do you have if you type ./xnview.sh?
Nothing happens again.
no error? no message?
junker
Post by junker »
Just nothing... no error nor message.
junker
Post by junker »
Now the problem of that strange qt file is solved... but it returned the problem of conflicts in filesystem... so XnConvert isn't still usable...
junker wrote:Now the problem of that strange qt file is solved... but it returned the problem of conflicts in filesystem... so XnConvert isn't still usable...
which conflicts?
junker
Post by junker »
The message by Gnome Software is:
Error running transaction: file / from install of xnconvert-1.76-2.x86_64 conflicts with file from filesystem-3.3-3.fc27.x86_64 file /usr/bin from install of xnconvert-1.76-2.x86_64 conflicts with file from filesystem-3.3-3.fc27.x86_64
junker wrote:The message by Gnome Software is:
Do you have tried the TGZ version?
junker
Post by junker »
Of course, nothing happens. It's the same problem as with previous Fedora versions.
i've installed Fedora 27 x64, and no problem to start XnView from TGZ package
