Draw module: Eyedropper cannot take the color for the 2ndary color?
m.Th.
Post by m.Th. »
In Draw Module (Shift+D) in Viewer the Eyedropper cannot load the 2ndary color? I tried with {Ctrl}, {Shift} or {Alt} pressed a la Photoshop but no luck.
If this feature is really missing I would suggest to use {Alt} as modifier like in Photoshop: single-click = 1st color. single-click while {Alt} pressed = 2ndary color.
m. Th.
Re: Draw module: Eyedropper cannot take the color for the 2ndary color?
click on second color without SHIFT/CONTROL/ALT
m.Th.
Post by m.Th. »
xnview wrote:click on second color without SHIFT/CONTROL/ALT
Perhaps I wasn't clear: I don't want to change the 2ndary color by clicking on it. I want to take a color from the image (using the Eyedropper) into 2ndary color.
How do I do this?
m. Th.
oh ok, right
See issue for current status and some details. I'll post here once the problem has been fixed.
This problem is supposed to be fixed in XnView MP 0.90. Please check and confirm the bug fix here.
m.Th.
Post by m.Th. »
Fixed
m. Th.
