Usability issue with preview of similar files search result
AnastasiyaZakh
Post by AnastasiyaZakh »
Environment: OS Windows 10 64bit
Version: 0.88 64bits (Nov 2 2017) Libformat version 7.12
Step to reproduce:
Tools-> Search similar files -> similar picture content 80% ->ok -> wait result
Actual result:
1. there is no expand window button
2. similar files thumbnails list is too small and there is no possibility to increase size
3. images are not protected from accidentally deletion, delete button proceeds immediately
4. when I close similar search files window, deleted files stay still visible in images browser
Expected results:
1. There should be the maximize button
2. There should be possibility to select thumbnail size from several predefined values
3. delete action should ask whether I am going to proceed
4. the program should send refresh event to image browser component after closing similar files window
Re: Usability issue with preview of similar files search result
AnastasiyaZakh wrote: 1. there is no expand window button
Maximize button of dialog?
yes currently no way
a confirmation box must be shown?
ok, i'll check
