Option to overwrite / replace all files?
kukris
Post by kukris »
when I copy or move files / folders from one folder to another and files / folders with the same name already exist there, a dialog pops up with various options.
Unfortunately there are no options to overwrite / replace all or skip all, so you have to either use the rename all option or manually confirm each file / folder.
Could you please add the options to overwrite / replace all files or folders?
I found this topic, but I don't know if it will be done or not.
viewtopic.php?f=34&t=24807&p=99941&hili ... all#p99941
Greetings
Kukris
