Is it possible to specify an RGBA color in GFLAx?
I have a colored map I want to draw transparent circles on to indicate populations, so I can see the town name under the circle.
Transparent colors for drawing?
Re: Transparent colors for drawing?
What do you want to make??b.e.wilson wrote:Is it possible to specify an RGBA color in GFLAx?
He wants to draw a circle using a semi transparent colour (RGB Alpha).xnview wrote:What do you want to make??b.e.wilson wrote:Is it possible to specify an RGBA color in GFLAx?
Houpshelmut wrote:He wants to draw a circle using a semi transparent colour (RGB Alpha).xnview wrote:What do you want to make??b.e.wilson wrote:Is it possible to specify an RGBA color in GFLAx?
