Wrong filesize in 'Generate file listing'
igor
Post by igor »
if xnview produces a file listing with the properties-box NOT checked, the filesize is wrong: it is the same for every file in the listing.
When the properties-box is checked, it's OK.
- os: Win2k
- xnview: tested on v1.80 and 1.80.3
Re: bug in 'generate file listing' with filesize
igor wrote:if xnview produces a file listing with the properties-box NOT checked, the filesize is wrong: it is the same for every file in the listing.
Sorry i can't reproduce this bug, could you tell me which settings do you have?
I've also tried on Win 2000 and XnView 1.80.3 - no problems.
igor
Post by igor »
steps to reproduce the bug on win2K v1.80.3:
- select some files in the browser
- 'generate file listing' (Shift+L)
- settings: checked 'size': size-type 'KB' (but problem occurs on other size-types as well)
result: notepad text-file with always 0 as result
However the different sizes return OK if the 'size'-checkbox is combined with 'properties' or 'type' or both.
I also had the same problem on another computer, also win2K, but with v. 1.80: there the bug occurs on the same combination of checkboxen, but the returned sizes are not zero, but some other value (but I have no idea what this value is).
igor wrote:steps to reproduce the bug on win2K v1.80.3:
Ok, i can now reproduce the problem...
