XnView MP won't open on macOS High Sierra
Fofinho
Post by Fofinho »
Hi im mad, i downloaded xnviewmp for mac and it never opens no matter what i do, i just get an error message. someone know why it doesnt open ?
Re: xnview won't open
which MacOSX?
Fofinho
Post by Fofinho »
macos high sierra
please check this topic
Fofinho
Post by Fofinho »
oh , its a poorly maintained program. it only runs on unsupported macos, seems xnview development stopped on macos years ago
Fofinho wrote:oh , its a poorly maintained program. it only runs on unsupported macos, seems xnview development stopped on macos years ago
The versions listed above are the last versions of XnView MP that run on earlier macOS versions, development continues for later macOS versions... :D
Fofinho
Post by Fofinho »
really? link me to a version that works with my version of macos , and if it works ill change my mind
Re: XnView MP won't open on macOS High Sierra
I'm not a macOS user, but the current XnView MP version 0.89 should run on High Sierra according to the linked post above...
Looks like a security issue from your screenshot, is there possibly an 'Advanced...' setting you can change?
Edit:
If you Google macos "identity of the developer" there are a number of links you might find helpful, for example this one:
App can’t be opened because the identity of the developer cannot be confirmed
Fofinho
Post by Fofinho »
cday wrote:I'm not a macOS user, but the current XnView MP version 0.89 should run on High Sierra according to the linked post above...
Edit:
ive unzipped and tried that one and i still get same results , and i already searched up that identity stuff and did the commands and it still didnt work , i show in the screen shot that i have allow apps from anywhere on. but its okay ,i found something much better than xnview called picasa
Fofinho wrote:but its okay ,i found something much better than xnview called picasa
… albeit “poorly maintained:mrgreen:
organicCPU (MacRumors Forums → [url=http://forums.macrumors.com/threads/2046458/#post-24594587]Digital Research/Atari .IMG images on the Mac[/url]) wrote:XnConvert is working perfect for me and able to convert Atari sample IMG files. Try installing again and open the app by right click -> context menu -> open (to bypass gatekeeper) or try downloading from the Mac App Store https://itunes.apple.com/app/xnconvert/id436203431
macstatic (MacRumors Forums → [url=http://forums.macrumors.com/threads/2046458/#post-24595566]Digital Research/Atari .IMG images on the Mac[/url]) wrote:The Mac app store version worked fine! I did the gatekeeper bypass thing, so there must have been something wrong with the file itself.
Anyway, XnConvert works great!
As a bonus, I got XnView MP to work as well.
Thanks for your suggestion for downloading from the App store and trying it out!
Fofinho wrote:ive unzipped and tried that one and i still get same results , and i already searched up that identity stuff and did the commands and it still didnt work , i show in the screen shot that i have allow apps from anywhere on. but its okay ,i found something much better than xnview called picasa
Please authorize third party app in macosx settings
This is what Apple says:
macOS Sierra: Open an app from an unidentified developer
there is an error with the cerficate i check...
i've fixed the problem on XnConvert app bundle, but currently i have always a problem with XnViewMP app bundle...
the signed problem is fixed for XnViewMP too
