0.89: Shortcut for lossless rotation (clockwise) doesn't work
Kaminari
Post by Kaminari »
XnView: MP 0.89 - 64-bit
OS: Windows 7 - 64-bit
Effect: CTRL+Shift+L doesn't do anything in browser and viewer modes. CTRL+Shift+R works as intended.
Since 0.88, I've noticed a strange bug: the keyboard shortcut for lossless rotation to the left (clockwise) doesn't work. Counter-clockwise still functions properly. I've tried resetting all shortcuts to default and deleting the default.keys file in Roaming, without any success.
Re: 0.89: Shortcut for lossless rotation (clockwise) doesn't work
works for me if i remove the default.keys
Kaminari
Post by Kaminari »
Then I don't understand what went wrong with this software.
Does XnViewMP store its keyboard settings in other places, like the INI file or the Registry? There might be leftovers from previous versions somewhere.
Kaminari wrote:Then I don't understand what went wrong with this software.
only in defaults.keys, and the shortcut is correct??
Kaminari
Post by Kaminari »
For info: the culprit was the recent edition of AMD Radeon drivers, which by default reserve the combination CTRL+Shift+L for performance monitoring (logging). It's a widespread issue which affects quite a number of applications, thankfully this hotkey is modifiable.
My bug report can be closed.
