Mouse Pointer Inconsistency
TheEvilHammer
I've noticed that if you right click on a folder in the folder tree in "browser" mode, the mouse pointer doesn't change to the normal "arrow" - it stays as the "pointing finger". This is bit odd - try right-clicking on a web link in a browser to see how it should look...
Right, but…
- Right, the hand-index cursor stays…
- Not a big deal, though; just a small trivial bug / lacuna
Re: Mouse Pointer Inconsistency
Correct, well spotted, EvilHammer. I've just tried to see how MS Explorer behaves and found that in folder tree the mouse cursor never changes (always "arrow". Not quite sure but perhaps this part should be changed.TheEvilHammer wrote:I've noticed that if you right click on a folder in the folder tree in "browser" mode, the mouse pointer doesn't change to the normal "arrow" - it stays as the "pointing finger". This is bit odd - try right-clicking on a web link in a browser to see how it should look...
The finger is setted by windowsTheEvilHammer wrote:I've noticed that if you right click on a folder in the folder tree in "browser" mode, the mouse pointer doesn't change to the normal "arrow" - it stays as the "pointing finger". This is bit odd - try right-clicking on a web link in a browser to see how it should look...
O.k., but at least it should be reset as requested by EvilHammer.xnview wrote:The finger is setted by windowsTheEvilHammer wrote:I've noticed that if you right click on a folder in the folder tree in "browser" mode, the mouse pointer doesn't change to the normal "arrow" - it stays as the "pointing finger". This is bit odd - try right-clicking on a web link in a browser to see how it should look...
But i don't change it, and it's the normal behaviour, i've checkedhelmut wrote:O.k., but at least it should be reset as requested by EvilHammer.xnview wrote:The finger is setted by windowsTheEvilHammer wrote:I've noticed that if you right click on a folder in the folder tree in "browser" mode, the mouse pointer doesn't change to the normal "arrow" - it stays as the "pointing finger". This is bit odd - try right-clicking on a web link in a browser to see how it should look...
TheEvilHammer
