Update and keep categories?
Nimrodel
Post by Nimrodel »
I used xnview MP version 0.88. I downloaded it as " Zip Win 64bit". Now I wanted to update to the new version 0.89, so I downloaded it again; but now I have two Xnview MP on my computer, one with the old version and all my categories, and one with the new version but "blank", with the standard-categories. What did I do wrong?
Re: Update and keep categories?
do you use custom folder for catalog?
Nimrodel
Post by Nimrodel »
Maybe, I'm not sure. Can you tell from these screenshots?
you use folder of XnView, so xnview.ini and all .db files are in this folder, you need to copy them in 0.89 folder
Post by michel038 »
...and the files that are later than 2018 02 14 ?
(default.keys, bookmark.ini, autocorrect.txt ... )
Nimrodel
Post by Nimrodel »
Ok, thanks a lot, it worked :-)
