Hello guys,
I have just installed XnView as an alternative to Irfanview.
The main reason being 99% of the time I am wanting to open an image, crop and rotate it, and then Save As over the original image.
The problem with Irfanview is I have to navigate to the folder containing the currently open image every time... this wastes a lot of time since this is what I use an image viewer for. Ideally it could open to the same folder as the one containing the open image by default.
I don't know if xnview can do this because I cannot find a way to Save As...
Help appreciated,
Thanks, Mark.
Save As... missing
Re: Save As... missing
if you open an image, you have 'save as'
