Favorites / Edit pathname then Cancel removes path
TommiG2
Post by TommiG2 »
Dear colleagues,
I found following bug.
1) using a working Favorites entry and doing right mouse click and "Edit pathname..."
2) dont change anything but just press Cancel in the select folder dialog
3) now the Favorites entry was changed to point "C:\" (but shouldn't of course)
Env: Win10 Prof 64bit, XnView MP 0.89 (Jan 15 2018)
Best regards,
Thomas
TommiG2
Re: Favorites / Edit pathname then Cancel removes path
Post by TommiG2 »
I tried the same on my Mac at home and there "Cancel" leaves the path untouched. So this is fine and seems only Windows version has this kind of bug.
Best regards
Thomas
TommiG2
Post by TommiG2 »
It is a poor signal, not getting any answer.
After 2 weeks of using I found so many problems und bugs and I am unsure if there is serious work on it even there is no notice of this problems.
Two weeks ago I found this could be a great product and I did my donation.
But now I am unsure if there are any interest and its wasted time to describe any problems.
Thomas
TommiG2 wrote:It is a poor signal, not getting any answer.
Sorry but i can't reply right now for every posts, but problems are checked asap
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
