Hello!
Looks like that there are some changes in recent version, before I used to click on the image from the windows explorer, Xn would start and show the image, when I press ESC it would exit back to windows.
Problem is that Xn now exit back to Xn browser which is not what I expect because before, if I needed browser, I would press ENTER and if I wanted to exit completely ESC would return me to Windows.
Any chance to skip to windows after viewing single image in Xn from windows explorer ?
(checked all the options in Xn settings but didnt find solution)
Thanks !
Re: viewing single image
do you have checked options>Keyboard>Pressing ESC...
igord2
Thank you sir, easy solution, didnt realized that there are multiple tabs in interface segment, believed that interface is just a header for the options that follow below (auto text correction and formats).
Thank you for your time.
