SlideShow: adding folder (not file)
derekw99
Post by derekw99 »
MP version should behave like the classic version: should be able to add "Folder" (currently in MP, if add folder, it expands all the current files in the folders). Should be able to add "Folder" and in the setting, have a checkbox to indicate "recursive into subfolder", as in the Classic version.
Also, the slideshow files are not compatible between Classic and MP version.
Re: SlideShow: adding folder (not file)
derekw99 wrote:MP version should behave like the classic version: should be able to add "Folder" (currently in MP, if add folder, it expands all the current files in the folders). Should be able to add "Folder" and in the setting, have a checkbox to indicate "recursive into subfolder", as in the Classic version.
yes right
you would like to have a feature to open Classic slideshow file?
This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
