How can I freely define the folder structure in the destination folder when importing, as with ACDSee?
I would like to use yyyy\yyyy-MM\yyyy-MM-dd\, as all images have been sorted in this way for years.
Thomas
free folder structure for import
Thomas_FTL
Re: free folder structure for import
ACDsee has encountered a system error and will close now.
I think it's very easy to program that the user is completely free in the folder structure and filename.
ACDSee has always been able to do that.
Thomas
Thomas
Thomas_FTL
How can I differentiate between EXIF date and file date when importing.
Thomas
Thomas
ok, i understand, you would like to use file date or exif date to create folder structure, right?
currently EXIF modified date is used (if not exists, it use file date)
