Wish: Save dialog should show existing files independent of case
dietmar
Post by dietmar »
Hi Pierre,
when you save_as a file to e.g. JPG, all existing JPGs in the selected folder are shown so you can select one to overwrite or select one to modify the name.
However, at least on Linux, only some of the existing JPGs are shown.
Given a folder having some JPGs with the extension .jpg and some with the extension .JPG, only the lower-case jpgs are shown. The upper-case JPGs are not seen.
I would like to see all JPGs, lower-case and upper-case and every mix thereof.
Regards
Dietmar
