[Linux] "Open with" context menu doesn't work (0.88)
pangwolin
Post by pangwolin »
In Viewer Mode, the Open With context menu fails to start the configured applications with the currently viewed file as argument.
I have tried adding "gimp", "gimp-2.8", "gimp.desktop", and xnviewmp does find the specified paths
lstat("/usr/bin/gimp", {st_mode=S_IFLNK|0777, st_size=8, ...}) = 0
but nothing happens. I saw this error (with strace) around the time the element is clicked in the menu, but it might not be related:
poll([{fd=5, events=POLLIN}, {fd=7, events=POLLIN}, {fd=13, events=POLLIN}, {fd=14, events=POLLIN}, {fd=20, events=POLLIN}], 5, 1425GEGL-geglmodule.c-Message: Module '/usr/lib/gegl-0.2/exr-save.so' load error: /usr/lib/libIlmImf-2_2.so.22: undefined symbol: _ZN7Iex_2_27BaseExc6assignERNSt7__cxx1118basic_stringstreamIcSt11char_traitsIcESaIcEEE
) = 1 ([{fd=5, revents=POLLIN}])
This is on Arch Linux. Can anyone reproduce?
Is there any documentation about the arguments the user can supply to these "open with" programs anyway? I have tried %U, %F, but I have no idea...
Re: [Linux] "Open with" context menu doesn't work (0.88)
do you have tried with another app?
pangwolin
Post by pangwolin »
I had not, my bad!
I have tried with 'feh' and it works just fine indeed.
It must be a quirk of GIMP then. It seems to actually be started judging from the error message below (the "gegl" one, probably not related to xnview), but it exits immediately after.
Is there something special that Xnview does for starting third party programs?
Sorry for adding noise, but thank you! :)
ok, i think that the problem is with libIlmImf, XnViewMP has a version too. Try to rename it?
pangwolin
Post by pangwolin »
Thanks, I have renamed my libIlmImf-2_2.so.22 to libIlmImf-2_2.so.22.BAK and it now starts Gimp just fine!
sudo mv /usr/lib/libIlmImf-2_2.so.22{,.BAK}
For the record, these are now showing up in console (causes no problem):
GEGL-geglmodule.c-Message: Module '/usr/lib/gegl-0.2/exr-save.so' load error: libIlmImf-2_2.so.22: cannot open shared object file: No such file or directory
GEGL-geglmodule.c-Message: Module '/usr/lib/gegl-0.2/exr-load.so' load error: libIlmImf-2_2.so.22: cannot open shared object file: No such file or directory
GEGL-geglmodule.c-Message: Module '/usr/lib/gegl-0.2/openraw.so' load error: libopenraw.so.7: cannot open shared object file: No such file or directory
libIlmImf-2_2.so is part of the "openexr" package, a 'high dynamic-range image file format library'.
Required By : gimp gst-plugins-bad kdelibs kio-extras krita opencv
Optional For : gegl02 libmagick libmagick6
Thanks. :)
