rosko
Post by rosko »
Hi there, what a great piece of software, thanks.
I have an issue I cannot solve though.
I need to change my input file from XX.jpeg to the output file of XX.jpg and cannot work out how to do it. It comes out as .jpeg still.
Any ideas please?
This is using the output of {Filename}
MUch appreciated!
Re: Output File Extension .jpg
which filename template do you use? do you change extension?
rosko
Post by rosko »
Hi Pierre,
The orginal image is a .jpeg and I need it to be changed to a .jpg.
I am simply using the filename selection of {Filename} with a JPG - JPEG/JFIF format since there is no other one applicable.
Using the current process it goes in as a .jpeg and comes out as a .jpeg. Then I have to reprocess the image via another program to change it to a .jpg.
Thanks for your help!
Thanks to your detailed description I can reproduce the problem. I'll add a setting to keep default extension or not.
