The latest XN-View MP Version has different problems with xml-files in root directories!
On my computer Virtual DJ is installed, which generates a "VirtualDJ Local Database v6.xml" file in the root directory of my music harddisc.
Here is a part of the file :
<?xml version="1.0" encoding="UTF-8"?>
<VirtualDJ_Database Version="741">
<Song FilePath="K:\Musik\01_LOTUS 2.wav" FileSize="29823020">
<Display Color="6985468" Tag="2" />
<Infos FirstSeen="1408281936" />
</Song>
<Song FilePath="D:\Musik\Discofox_Tanzmusik_mit_BPM\130bpm - DJ Ötzi - 7 Sünden.m4a" FileSize="9747241">
<Display Author="DJ Ötzi" Title="7 Sünden" Genre="Pop" Album="Best Of DJ Ötzi" Year="2006" Color="6713426" Cover="2" Tag="1" />
</Song>
<Song FilePath="D:\Musik\Discofox_Tanzmusik_mit_BPM\128bpm - Mika - Rain.m4a" FileSize="8807900">
<Display Author="Mika" Title="Rain" Genre="Pop" Album="128bpm" Year="2010" Color="2415533" Cover="2" Tag="1" />
It contains informations about my music files on the harddisk.
You can try it yourself, because there is a free trial version on http://www.virtualdj.com.
If I read the root directory of this music harddisk (with the virtual dj xml-file) in XnView MP, I will get text overlays in the lower status bar. I use the german language settings.
If I close xn-view-mp and start it again, xn-view-mp will crash after starting the program.
I am very sure, that the problem is the virtual dj xml-file, because I renamed the file and everything work fine!
Please fix it! Thank you!
0.90 - status bar text overlapping in browser view - xml-file produce error
masterjp
Re: 0.90 - status bar text overlapping in browser view - xml-file produce error
could you post the xml file, there is some chars encoding problem
