Good Sunday to all !
I discovered this little logician very accommodating to make vignettes. But they are still much too small despite my setting as 250x250 pix. I did several tests and always the same result. I do not find. really not what is wrong. My values are never considered. The result is that when they are close to the icons in the document folders they remain disproportionate compared to the thumbnails of documents that are almost three times larger. I would like to find out what's wrong. I'm sure to experiment ... or suggest an easier program to correct the sizes of the stickers made. I enclose an image that compares Xnune normal vignette of size compared to a composite with XnView. That of the center in blue is the one composed with XnView by taking the image to convert it into an icon (vignette)!
VIGNETTES , ICO ARE TOO SMALL
rayal
