Catalog Rating and Label not updated with "Update catalog from file"
Walter-Sony
Post by Walter-Sony »
XnView: MP 0.90 - 64 bit
OS: Windows 7/64bit
Description:
If I use the catalog activated. I change a rating or color label of a jpg-file in another program (Windows, ACDSee, Photoshop). XnViewMP does not notice this and keeps the rating and label of his own catalog.
This is also the case, if I restart XnViewMP or I start "View - Update catalog from file". The last only updates the keywords, but not the rating or color label.
Only if I kill all catalog information, all files are read again and the rating and label is set to the value written in the file.
Effect: Wrong file information in catalog about rating and label
Actual behaviour (bug): Rating and color label is not actualized if file date is changed.
Expected behaviour: XnView updates ALL XMP ITCP metadata (rating and color label inclusive), if the file date is changed. At least if I choose "View - Update catalog from file"
Regards
Walter
Re: Catalog Rating and Label not updated with "Update catalog from file"
the file date is changed?
I've tried with Windows, the file data is not changed, and 'update catalog' works correctly
Walter-Sony
Well, at my PC it is not working. I posted the settings and picture with metadata shown.
you need to enable the first setting 'Import XMP subject'
Walter-Sony
Thanks for the clue, but it changed nothing.
Regards
Walter
plaese send me your xnview.ini and a jpg sample file?
