0.90: Batch Convert to Guetzli JPEG, does not produce files
Evan
Post by Evan »
[xnview MP v0.90, Windows x64]
The Batch Converter does not produce the JPG files, when the Format is set to JPG - Guetzli JPEG. The process shows that it completes successfully, and that the files are produced, but they are not.
Thanks
Re: 0.90: Batch Convert to Guetzli JPEG, does not produce files
Evan wrote:[xnview MP v0.90, Windows x64]
Thanks
There is a known issue related to the minimum quality setting required to be selected (Q=84), as eventually identified in the following post from a long thread:
0.88: Batch-Convert - Guetzli JPEG not working
