Files name "#"
ThunderWarrior
Files name "#"
Post by ThunderWarrior »
When you are playing Batch COnversion (Ctrl+U), using the output tag, you can choose the filename, format, etc.....but XnView doesn't allow you use the "#" character in the filename.
Could you change this?
Re: Files name "#"
sorry but you can't choose # in output filename
ThunderWarrior
Re: Files name "#"
Ok. Thanks anyway.
