Converting SVG to PNG maintaining transparency
shermanf
Post by shermanf »
Hi Everybody!
I was hoping someone could help me...
I am converting a bunch of SVG files to PNG..
they all are converting fine, but on the SVG images that are transparent, the converted PNG files
are showing the checkerboard background..
Can anyone tell me how to convert transparent SVG files to PNG files while retaining the transparent background??
THANKS so much for the great software and any help from anyone!
Have a great day :D
shermanf
Re: Converting SVG to PNG maintaining transparency
Post by shermanf »
ANYONE?? No one knows the answer to this ?? I am really stuck guys... any help would be so appreciated,
Thanks everyone! :shock:
Welcome to the forum, shermanf.
Please refer to “How do I open SVG files and convert to PNG”.
by default, PNG keep SVG alpha, could you post a sample file?
Rehvaro
Post by Rehvaro »
Hello.
I'm relaunching this post as I have the exact same problem and can help to investigate it if needed.
I'm joining three example files, the original, the result, and the xbs saved by XnConvert
Thank you.
