I tried as hard as I could and couldn't find an option for this, so I ask: is it possible to disable antialias when you zoom in on an image? At the moment it does, for me, (bilinear?) filtering/smoothing.
Especially if I am looking at pixelart, when I zoom in from, say, a 320x256 image, it's not really cool to have that getting filtered, raw jaggy hard pixels would work best.
If this is not possible at the moment, can a moderator please move this to suggestions? And in such a case, can i ask if it can be implemented as an option we can toggle on/off?
Thanks!
Disable antialias on zoom?
Re: Disable antialias on zoom?
Could you please look at Tools > Settings > View tab -- High zoom quality and see if that provides the solution you need?
kdrone
Oooooh disabling it disables the filtering, that was kinda unintuitive.
Now pixel art looks blocky-good!
Thanks so much for your help!
