Is it possible to send each new file as a separate print job when sending files to print? This is necessary for example, in order to print 4 images on 1 sheet with the printer settings set, the next file was printed on the next sheet.
Thank You!
Printing files separately
Re: Printing files separately
You wish to print multiple different images on the same sheet, or multiple copies of the same image on one sheet?alexey_kor wrote:Is it possible to send each new file as a separate print job when sending files to print? This is necessary for example, in order to print 4 images on 1 sheet with the printer settings set, the next file was printed on the next sheet.
Could you please confirm that you are using XnView Classic and have looked at the File > Print... and File > Print opened images... if that is relevant?
Otherwise, could you please try to clarify what you wish to do.
