XnView MP 0.90 Rotate Bug
obelisk
Post by obelisk »
After going to .9, I noticed sometimes some files aren't rotated right.
I would have a jpg file from camera. Then I use LR to make RAW->jpg. This file looks rotated in XMP. Fine in everything else. If I open this jpg in PS and edit and save, then it's fixed in XMP again.
masterjp
Re: XnView MP 0.90 Rotate Bug
Post by masterjp »
JPEG picture files of your camera has EXIF-Information which contain information about the rotation.
Some programs rotate the whole picture information about 90, 180 or 270 degree, intelligent programs change only the EXIF-Information about the rotation.
XnView MP can change the EXIF-Information or rotate the whole picture.
obelisk
Post by obelisk »
XnView MP does not DISPLAY correctly.
obelisk
Post by obelisk »
Use exiftool with this to test
-adobe:all= -exif:all= -xmp:all= -photoshop:all= -tagsfromfile "source.xmp" -iptc:all  -xmp:all -overwrite_original -ext jpg -r %*
obelisk
Post by obelisk »
xmp tags just have iptc copyright fields.
XnView MP0.9 is the ONLY program to rotate things wrongly.
all other browsers, editors, viewers work.
do you have sample file to reproduce?
obelisk
Post by obelisk »
Take any file and run exiftool
I've moved back to 0.87 and it works perfectly since then.
obelisk wrote: Wed Apr 18, 2018 7:43 am Take any file and run exiftool
what do you have in source.xmp? you don't change orientation with exiftool?
vertigo
Post by vertigo »
Try opening the image in GIMP. It's the only program I'm aware of (though there could be others) that indicates when the Exif data doesn't match with the actual rotation. As previously mentioned, some cameras and software "rotate" images by just changing an Exif field, and others actually rotate the image by moving all the pixels, which is more computationally intensive. The best fix I found for this is JPEG Autorotate, which physically rotates the image to match the Exif data. I'm assuming the problem here is that XnView MP is using the actual rotation vs using Exif data, though I could be wrong.
obelisk
Post by obelisk »
xnview wrote: Sun Apr 22, 2018 9:05 am
Where is this source.xmp file?
obelisk
Post by obelisk »
Any news on this?
-adobe:all= -exif:all= -xmp:all= -photoshop:all= -iptc:all  -xmp:all -overwrite_original -ext jpg -r %*
<?xpacket begin='' id='W5M0MpCehiHzreSzNTczkc9d'?>
<x:xmpmeta xmlns:x='adobe:ns:meta/' x:xmptk='Image::ExifTool 9.89'>
<rdf:RDF xmlns:rdf='http://www.w3.org/1999/02/22-rdf-syntax-ns#'>
 <rdf:Description rdf:about=''
  xmlns:Iptc4xmpCore='http://iptc.org/std/Iptc4xmpCore/1.0/xmlns/'>
  <Iptc4xmpCore:CreatorContactInfo rdf:parseType='Resource'>
   <Iptc4xmpCore:CiAdrCity></Iptc4xmpCore:CiAdrCity>
   <Iptc4xmpCore:CiAdrCtry></Iptc4xmpCore:CiAdrCtry>
  </Iptc4xmpCore:CreatorContactInfo>
 </rdf:Description>
  xmlns:dc='http://purl.org/dc/elements/1.1/'>
  <dc:creator>
   <rdf:Seq>
    <rdf:li>Bob</rdf:li>
   </rdf:Seq>
  </dc:creator>
  <dc:rights>
   <rdf:Alt>
    <rdf:li xml:lang='x-default'>All rights reserved</rdf:li>
   </rdf:Alt>
  </dc:rights>
 </rdf:Description>
  xmlns:xmpRights='http://ns.adobe.com/xap/1.0/rights/'>
  <xmpRights:Marked>True</xmpRights:Marked>
  <xmpRights:UsageTerms>
   <rdf:Alt>
    <rdf:li xml:lang='x-default'>No reproduction without prior permission</rdf:li>
   </rdf:Alt>
  </xmpRights:UsageTerms>
 </rdf:Description>
</rdf:RDF>
</x:xmpmeta>
<?xpacket end='w'?>
please could you send me sample files to reproduce the problem? And describe the way to reproduce...
obelisk
Post by obelisk »
I've given you the files. Take any photo from your camera.
https://www.sno.phy.queensu.ca/~phil/exiftool/
sorry but i don't understand the problem, please describe all steps to reproduce...
obelisk
Post by obelisk »
You use your camera take a jpg + RAW.
use LR to make RAW->jpg in the same folder
This file now looks rotated WRONGLY in XnView .
It looks CORRECT in all other viewers.
