XnView MP 0.90 Rotate Bug
Moderators: XnTriq, helmut, xnview, Dreamer
Re: XnView MP 0.90 Rotate Bug
Hi, did you get that? I tried 99.7 and a problem with one file dated 20180326.
Hi again, in v1.00 (!!) the bug is back. Jpg are rotated by instructions in xmp file. Thumbs are fine, opening it rotates wrongly.
I say again, jpg uses exif, not xmp.
Photo is vertical (exif rotate?)
xmp from Lr, (rotate)
You are taking both commands.
Take xmp away, no problem.
Same as oroginal in 0.87
See viewtopic.php?p=170913#p170913
and whatever fix you did then, that was undone.
viewtopic.php?p=170984#p170984
Not easy to follow, please send the steps to reproduce, and image testobelisk wrote: ↑Wed Jun 08, 2022 7:27 am See viewtopic.php?p=170913#p170913
