mrG0bliN
Post
by mrG0bliN »
os: windows 10 x64
see path to my img, i click png picture and all work
now i put my img in folder "hello name", and file not found O_O
Post
by xnview »
do you have this error with only this path?
mrG0bliN
Post
by mrG0bliN »
xnview wrote:do you have this error with only this path?
"file not found" - image text
everywhere, if path image name have "space" =\
Post
by xnview »
please check the registry entry for this extension, it seems that you have an error
mrG0bliN
Post
by mrG0bliN »
xnview wrote:please check the registry entry for this extension, it seems that you have an error
i use xnview.ini in root folder
can you help me find this property?
Post
by xnview »
mrG0bliN
Post
by mrG0bliN »
xnview wrote:start regedit, and search key for .png
this is the correct path and it works, but 'space' in picture path does not
mrG0bliN
Post
by mrG0bliN »
i reinstall programm in new root and problem not leave me alone
i think bug in my totacommander, so this topic you can close
Post
by xnview »
mrG0bliN wrote:i reinstall programm in new root and problem not leave me alone
the key seems to be good. you use totalcommander to start xnviewmp? no problem with other app?
mrG0bliN
Post
by mrG0bliN »
xnview wrote: Thu Apr 05, 2018 5:25 am
i fix it, The problem was with the file Wincmd64.ini in TC
I fixed the path and XnView continued to run perfectly, thanks
