Converting TIF to JPG - Not possible to add colour profile SRGB?
pm2003
Post by pm2003 »
Hi all!
I have a problem. Searched already a lot but no success... :(
I want to convert TIF files to JPG files.
This is working perfectly fine!
BUT I want to add the SRGB profile to the JPG files.
And I didn´t find a solution for that!
I am on XnviewMP 0.89. I have added a ICC convertion task and I have added a SRGB profile in the field output. Input field I have left empty. Tried 2 times (Activate/Deactivate) with the field IGNORE EMBEDDED PROFILE but nothing changed.
Any ideas how to do that?
Thanks a lot!
pm2003
Re: Converting TIF to JPG - Not possible to add colour profile SRGB?
could you send me the TIF file, and a screenshot of 'ICC convert'?
pm2003
Post by pm2003 »
I will do tomorrow!
Thank you very mutch Pierre...
pm2003
Post by pm2003 »
Hi Pierre!
Did you get my message with the link?
Peter
no, do you have sent it to 'contact at xnview dot com'
pm2003
Post by pm2003 »
I have sent again!
if you keep empty output profile, the result wil have sRGB.
Else send me the sRGB profile used
pm2003
Post by pm2003 »
Problem solved, thank you Pierre!
