Does MP works only with 24bits TIFs?
AAM
Post by AAM »
Is this a normal behaviour?
1. I opened in MP a 48bits TIF.
2. I adjusted the TIF using the Luminosity curve and I save the image.
3. The image got converted into 24bits.
What am I making wrong? Does Xn View MP can only save the files up to 24 bits?
Thank you.
Re: Does MP works only with 24bits TIFs?
Component of pixel are always converted in 8bits, if you want to keep 16bits per component only NConvert can do the conversion
