XnViewMP 0.90 - grid settings are not saved
masterjp
Post by masterjp »
I often crop photos and use the "show grid" function to cut them with the "golden cut".
XnViewMP does not save the last time used settings in the grid settings dialog.
There is a preset function (load/save), but I do not want to load it every time I open a new picture file.
That is very annoying.
Please add a function to save the last used settings in the registry or .ini file. - Thank you.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: XnViewMP 0.90 - grid settings are not saved
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
masterjp
Post by masterjp »
Now it works perfect! Great!
