I have been trying to find out myself and got lost on Internet reading about DPI and PPI and resolution and whatever
Would it be possible to add a column showing total size in pixels ?
Is that just W x H (e.g. 512 x 650) = 332800? Or does it depend on screen resolution?
Sorting on total pixels I could batch delete small images without having to view them one by one.
Calculate total number of pixels
Re: Calculate total number of pixels
total pixels = W x H, Size in inches or cm depend of DPI
mrwul
Then, I assume, this is correct then ?
mrwul
Thanks.
I've looked all over Internet, checked out quite a number of imageviewers (within VM) - but haven't found any image viewer that offers a column with with 'Total Pixels'.
I have another thread about how I can filter/select and then batch delete images that are below a specific size, because they show up too small on the monitor. Maybe .. it would be an idea to add such a column?
Some images are portrait shot photos, other are landscape.
So, I can not sort on Width only and delete all with a small width, because photos are shot portrait and as portrait shot, they have a decent size.
My guess is that I should then delete images below a certain 'total pixels'-size, because they are then just too small, no matter width or height.
Just a suggestion.
Just a suggestion.
mrwul wrote: Sat Apr 28, 2018 11:49 am I've looked all over Internet, checked out quite a number of image viewers (within VM) - but haven't found any image viewer that offers a column with with 'Total Pixels'.
Maybe, but if no existing image viewer displays Total Pixels that suggests that there is little need for the function... It would probably be easy to add, but Pierre has a high workload at present.
mrwul wrote: Sat Apr 28, 2018 11:49 am Some images are portrait shot photos, other are landscape.
So, I cannot sort on Width only and delete all with a small width, because photos are shot portrait and as portrait shot, they have a decent size.
As images normally have a reasonably low ratio of width to height, maybe in practice you could select images using just a minimum width, for example?
Or if not, determine minimum width pixel dimensions, and minimum height pixel dimensions, and then check that both are satisfied?
