Crashing
Re: Crashing
the problem is new? since an update?
Stephen0523
Re: Crashing
Yes just started. Trying to reset XN View.
Stephen0523
Re: Crashing
This is driving me crazy, there has to be an easy way to reset to factory!
Re: Crashing
to reset it, you can rename the ~/.config/xnviewmp/xnview.ini
Stephen0523
Re: Crashing
Got it working, but where is the config file exactly?
Re: Crashing
in .config folder on your home folder
