I did search the manual, forum and Google but could not find a clear answer to my questions so I post them here:
- How can I do noise reduction (denoise) with XnViewMP on Mac?
- Does XnViewMP on Mac support plugins?
- Are there denoise plugins that work with XnViewMP?
Regards,
Tony
Noise reduction (aka denoise) with XnViewMP on Mac?
tony124
Re: Noise reduction (aka denoise) with XnViewMP on Mac?
If you haven't done so already, could you check whether the Image > Filters... filters, which include a filter for noise reduction, work on a Mac?tony124 wrote: Wed May 02, 2018 10:01 am I did search the manual, forum and Google but could not find a clear answer to my questions so I post them here:
Otherwise, there is the possibility of using Adobe Photoshop plug-ins in the same menu.
tony124
thank you @cday for the hint. I will try the filter tonight when I get home, cannot do it now at work.
There is no menu item for Adobe Photoshop plugins in the menu; actually I saw that in some screenshot and was looking exactly for it before I posted my question. So I thought perhaps it's not supported for XnViewMP on Mac.
I've checked and Adobe 8BF plug-ins seem to be only designed for Windows...tony124 wrote: Thu May 03, 2018 8:30 amThere is no menu item for Adobe Photoshop plugins in the menu; actually I saw that in some screenshot and was looking exactly for it before I posted my question. So I thought perhaps it's not supported for XnViewMP on Mac.
tony124
I have tried the denoise filter on a few photos but it doesn't seem to do anything.
Do you have an image you could upload that Pierre could use to easily check operation of the filter on a Mac?tony124 wrote: Tue May 08, 2018 7:57 am I have tried the denoise filter on a few photos but it doesn't seem to do anything.
