Multiple DB?
elfroggio
Multiple DB?
Post by elfroggio »
XN 0.90
Is it possible to have 2 DBs?
I have photos on drive 1 and on drive 2.
Drive 2 is my "dump" hd. Everything from the cameras with the camera names DSC,IMG... I use it to delete images, rename images... I use XN to tag, delete and rename the images.
Drive 1 is my "work" hd. After I'm done, I copy (not move) the files that I'm interested in to drive 1. I use XN to categorize and label the images.
So right now, a lot of the images are duplicated on both ==> also in XNViewMP.
Is there a way of either having 2 DBs or what to else could I do?
Thanks
Syv
Re: Multiple DB?
you can use multiple .ini with different DB configuration, and start
xnviewmp -ini myini.ini
Gérard 91
Re: Multiple DB?
Post by Gérard 91 »
Pierre,
Would you be kind to explain a bit more for "a dummy"
Thanks in advance
Gérard
Re: Multiple DB?
you can create 2 differents configuration with 2 differents database location, change only the dbThumbFolder/dbThumbFlag
and start xnview with -ini parameter
Gérard 91
Re: Multiple DB?
Post by Gérard 91 »
Thanks Pierre for your advise
I'll try
Gérard
