Ability to resize the xnview options window
klumy
Post by klumy »
sometimes you need the overview in the cache area, where you have to resize the window to a bigger size, so that you can see all directory names and sizes
XNView 1.91.5
Windows XP SP3
Re: Ability to resize the xnview options window
klumy wrote:sometimes you need the overview in the cache area, where you have to resize the window to a bigger size, so that you can see all directory names and sizes
Sorry i don't understand...
klumy
Post by klumy »
the optionwindow just should be resizable ;)
so that you can see the other columns in the cachemenu
XNView 1.91.5
Windows XP SP3
Not enough---
:arrow: klumy
:) Hello !
• As a workaround, you could use ResizeEnableRunner a tiny program that does the trick, I tested for the Option boxes… hummm… with a special language DLL, though :P
- But it works fine with the embedded English too…
:mrgreen: Kind regards,
klumy
Post by klumy »
basically all windows (like batchconvert, rename) should be resizable, to have a better overview on big screens
XNView 1.91.5
Windows XP SP3
marsh
Post by marsh »
klumy wrote:basically all windows (like batchconvert, rename) should be resizable, to have a better overview on big screens
I agree.
The little hack program linked above is also interesting.
ckit
Post by ckit »
I support your request 100000000% - it's Futurama logic :)
But it'll have to wait for XnView 1.83.
GeorgD
Resizable options dialog
Post by GeorgD »
klumy wrote:the optionwindow just should be resizable ;)
+4 and wanted to bring this wish to front again. Making a window resizable is usually just a parameter change in a function call, so very quick to implement. Also consider other windows like export etc - there are topics on that:
* in XnView MP http://newsgroup.xnview.com/viewtopic.php?f=60&t=18622&
* XnView classic http://newsgroup.xnview.com/viewtopic.php?f=34&t=10388&
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
Re: Resizable options dialog
No :-) it's not easy at all, yes make the dialog resizable is not a problem, but all control in it must follow a layout. In win32, there is no layout....
GeorgD
Post by GeorgD »
xnview wrote:No :-) it's not easy at all, yes make the dialog resizable is not a problem, but all control in it must follow a layout. In win32, there is no layout....
Bad news that the framework is not comfortable at that point :( In XnViewMP, options is already resizable. In Win32, is it easy to recognize screen size and set dialogs dependent on that, e.g. to 66% of screen size? So on my laptop (1024x768) the dialog would be smaller than on my external monitor (1600x1200).
GeorgD wrote:Bad news that the framework is not comfortable at that point :( In XnViewMP, options is already resizable. In Win32, is it easy to recognize screen size and set dialogs dependent on that, e.g. to 66% of screen size?
It's win32, the first UI of Windows :-)
