With EXR filter active it won't show new EXR new files icon
vicsharx
Post by vicsharx »
It will ignore any new file even I can see it pops briefly the icon when the file is copied but disappear quickly. We need to leave the filter to see the new pic and in that point we can return to the filter and see also the new pic.
This problem is not present in JPG, I didn't try other file formats.
Tested with XnView MP 0.90 beta 1
Re: With EXR filter active it won't show new EXR new files icon
you copy a exr file with file manager, in XnViewMP the file doesn't appear? Which filter do you use?
vicsharx
Post by vicsharx »
I type exr in the filter box
Any new exr added with this filter active won't show up. I need to leave the filter.
vicsharx wrote: Wed May 23, 2018 9:38 am I type exr in the filter box
i can't reproduce, new exr file are added in the filtered thumbnail view
vicsharx
Post by vicsharx »
I can reproduce it always. Using XnViewMP 0.90 beta 1 using windows 10
The new files are added to the folder in the background with a renderer, not using XnViewMP
vicsharx wrote: Tue May 29, 2018 8:13 am I can reproduce it always. Using XnViewMP 0.90 beta 1 using windows 10
please send me your xnview.ini
vicsharx
Post by vicsharx »
i can't reproduce
- you enter exr in the filter
- in windows explorer, you add a exr file
- in XnView's browser, the exr doesn't appear?
vicsharx
Post by vicsharx »
I will try to screen record it.
vicsharx
Post by vicsharx »
https://www.dropbox.com/s/ieh8vqg221axn ... 2.mp4?dl=0
In this case it crashes
I have create a filter for exr in Xnview MP and then copied several EXR in the same folder with windows explorer. When XnView MP start to read the new files it crashes.
i can't reproduce, is it possible to have sample files used?
