Status bar or title bar items
vicsharx
Post by vicsharx »
Is there any place in settings where I can change the items displayed in the status bar? (ISO, etc)
I know it is possible to change the title bar items in view mode but I can not find it in browser mode.
Re: Status bar or title bar items
currently no way
vicsharx
Post by vicsharx »
It seems would be a very useful feature as you can customize what relevant data appears and you have the code for similar function in view mode.
I know is possible to use the info when hovering, but it is a bit unreliable and I find myself waiting lots of times to appear when changing to another row as it is a lot slower that when changing columns between thumbnails.
so a extra item in the status bar to show custom info?
vicsharx
Post by vicsharx »
The same than the view window where you can edit what items appear and how appear, that is great. Even is possible to add text descriptions to the fields.
That system is also used when hovering over the thumbnail, the overlay on the view window in adition to the title bar and perhaps in more places.
Being so good why dont use it more.
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
vicsharx
Post by vicsharx »
Solved for the title bar
I can not find it for status bar. I need to point that this is secondary compared with the title bar, simply double checking I'm not missing it in the preferences menu.
m.Th.
Post by m.Th. »
fixed 0.91b1 (for the title bar which is the most important).
m. Th.
