Rename actions in batch processing
Tschens
Post by Tschens »
It would be very helpful to rename different actions in the batch processing list. You could for example define several different resizing actions and name them:
Resize to 800*600
Resize to 1200*1080
--> Very easy to choose and activate the required action.
Tschens
Olympus OMD E-M1, BS Kinetics underwater housing, 2xSubtronic pro 160 flashes. Zuiko mFT lenses: 60 macro, 7-14, 8 mm fisheye, 12-100, PanaLeica 100-400.
My Homepage | My book at Amazon
m.Th.
Re: Rename actions in batch processing
Post by m.Th. »
Tschens wrote: Mon May 14, 2018 2:03 pm Hello,
Resize to 800*600
Resize to 1200*1080
Tschens
I just save the list of actions with the desired name. See in the lower-left corner of Batch Convert dialogue.
m. Th.
Tschens
Post by Tschens »
This doesnt make sense for me, I dont see a reason to have more than one list. Since you can enable/disable each single action in the list, it would make more sense to rename them. Currently, each resize action is called "resize". I would rather like them to be named "Resize to 1024x768" or "Resize to "640*480".
Tschens wrote: Thu May 24, 2018 11:04 am This doesnt make sense for me, I dont see a reason to have more than one list. Since you can enable/disable each single action in the list, it would make more sense to rename them. Currently, each resize action is called "resize". I would rather like them to be named "Resize to 1024x768" or "Resize to "640*480".
could you explain me more what you would like?
Tschens
Post by Tschens »
Sure. This pic shows it.
