Wallpaper shortcut?
ZoNi
Wallpaper shortcut?
Is there any way to use some keyboard shortcut to make a picture - to be a wallpaper? Even better would if there is a button for that
No button
- I don't know for a short cut (it seems possible, though), but the addition of a button in the tool-bar is impossible currently… Please, give a glance HERE.
ZoNi
Setting as Wallpaper can be done in various ways (Centered, Tiled, ...). I assume that you need a shortcut for "Tools > Set as Wallpaper > Centered".ZoNi wrote:I hope that shortcut will be implemented soon...
At the moment, there's even no mnemonic (Alt+<key>) for these menu items. With Alt+T you open the Tools menu, but then you are stuck.
I think we should add more mnemonics, again (applies for all languages).
ZoNi
ZoNi
Re: Wallpaper shortcut?
any news regarding this?ZoNi wrote:Is there any way to use some keyboard shortcut to make a picture - to be a wallpaper? Even better would if there is a button for that
Sorry not addedZoNi wrote:any news regarding this?ZoNi wrote:Is there any way to use some keyboard shortcut to make a picture - to be a wallpaper? Even better would if there is a button for that
Dreamer
I'm affraid it's too late for 1.82. But I'll add it to Hotkeys / Shortcuts Request List.ZoNi wrote:I know it is not addedbut, I hope I will see that in near future
Edit: Added:
- Set as Wallpaper - Centered - Ctrl+Shift+Numpad *
- Set as Wallpaper - Tiled - ?
- Set as Wallpaper - Fit to Desktop - ?
- Set as Wallpaper - Best Fit to Desktop - Ctrl+Shift+Numpad /
- Set as Wallpaper - Previous - Ctrl+Shift+Z
