Rotate icon does not work
ST
Post by ST »
open a pic, click the rotate icon, & nothing happens. the main menu thing works
Works like a charm---
:) Hello !
- It works perfectly here. The function doesn't work for animated GIFs only, that is normal. In this case, the button is blurred (grey).
- Win XP-Pro - XnView 1.80.3
:mrgreen: Kind regards,
Cko
TheEvilHammer
Post by TheEvilHammer »
Also, your embedded thumbnail may be incorrect and causing problems with operations such as rotating.
Re: Rotate icon does not work
ST wrote:open a pic, click the rotate icon, & nothing happens. the main menu thing works
Your file might be write-protected.
