XnShellExtension Beta version
Moderators: XnTriq, xnview
Post by xnview » Thu May 31, 2018 10:07 am
The new 'BETA' version is available HERE
Please tell me if you find a bug...
- UNICODE support
- Resize menu (works with XnViewShellExt-Resize.txt file)
- Some bugs fixed
ckit
Re: XnShellExtension Beta version
Post by ckit » Fri Jun 01, 2018 12:49 pm
Fails to register for me, both the BAT way (which should also have a CMD version for x64 setups) and good old CMD prompt way.
Windows 10 Pro x64 1809 and Malwarebytes Premium
XnViewMP and Classic and PhotoFiltre Studio X
Post by xnview » Fri Jun 01, 2018 3:18 pm
could you try to add in the folder this file
ckit
Post by ckit » Sat Jun 02, 2018 1:03 am
Made no difference, I already have C:\WINDOWS\system32\msvcr120.dll and should be in the Windows Registry
Update:
Just tried installing the old 3.5.1 version (ZIP package) and same error!
Installer for 3.6.0 works Fine when installing to C:\Program Files\XnView\ShellEx or to C:\XnShellEx64
ZIP package is unusable on Windows 10
Post by xnview » Mon Jun 04, 2018 10:29 am
Update:
you need to open a command shell with admin rights, and type register.bat
ckit
Post by ckit » Mon Jun 04, 2018 2:05 pm
Yes, my bad I was trying to use CMD inside XYplorer
Launching from Cortana with Admin works
Post by xnview » Thu Jun 07, 2018 10:14 am
no bugs?
ckit
Post by ckit » Thu Jun 07, 2018 10:40 am
Not so far
